Corsa D OPC Nürburgring-Edition
Diskutiere Corsa D OPC Nürburgring-Edition im Smalltalk Forum im Bereich Diverses...; Das hab ich anders gehört Motor serie SW nicht
turbo-ben
turbo-ben
bei Augsburg
Der Motor muss doch eigentlich schon ein A16... sein oder? Z16 ist ja die ältere Abgasnorm.
Basti80
Basti80
Sachsen Anhalt
in England hat er 5PS weniger - dort ist er mit 98Oktan angeben.
von der VXR Homepage:
Corsa VXR NÜrburgring: Specification
At the heart of the Nürburgring is a re-worked version of the Corsa VXR’s existing 1.6-litre turbocharged engine which now produces 205PS* at 5,750rpm (up from 192PS) and 250-280Nm of torque (up from 230-266Nm). A modified engine management and turbocharger system, sports exhaust with reduced back pressure - and the ability to run on 98-octane fuel - have all contributed to the rise in power.
To harness the Nürburgring’s new-found power potential, Vauxhall has fitted it with a mechanical, multi-plate limited-slip differential, ensuring that its 205PS doesn’t go up in a cloud of tyre smoke, and providing the car with optimum traction at all times. The LSD also reins in understeer caused by excessive throttle loads during cornering, or changes in the texture of the road surface.
But perhaps the icing on the Nürburgring’s cake is its chassis, which received its final sign-off at the Nürburgring’s notorious Nordschleife, or North Loop. Vauxhall commissioned Bilstein to develop bespoke spring and damper units for
the new model, allowing drivers an even higher degree of control and involvement. A visual clue of this work is a ride height which is reduced by 20mm at the front and 15mm at the rear.
Complementing this are newly developed Brembo brakes, which are 30 per cent lighter than before, and have high-performance brake linings covering a 10 per cent larger area. In addition, the Corsa VXR’s ABS, Traction Control and Electronic Stability Control systems have all been recalibrated to take into account the Nürburging’s new set-up.
With performance of 0-60mph in just 6.5 seconds and a top speed of 143mph, the Corsa Nürburgring will deliver all the driving thrills you’d expect from a car wearing the legendary track’s name. But just in case anyone was in doubt, the new model gets a raft of visual identifiers: a stainless steel dual exhaust, newly designed forged aluminium wheels in high-gloss grey, and ‘Nürburgring’ logos on the B-Pillars and front spoiler lip. There are also two new colours available – apple green ‘Grasshopper’ and red ‘Henna’.
Inside, black and red ‘Nürburgring’ lettering adorns the sill plates and front Recaro seat backs, with bespoke white stitching on all seats, as well as the handbrake and gearshift console.
*Using 98-Ron unleaded fuel
Go Back
happydee45
happydee45
Ergebnis der Opel Ersatzteilsuche am 24.07.2011:
Teil Nummer 13370589
Katalognummer 1400912
Bezeichnung ABWEISER
Preis € 48,57
Preis gültig seit 21.07.2011
Corsa D OPC Nürburgring-Edition - Ähnliche Themen
Opel Corsa D OPC Getriebe: Hallo OPC-Gemeinde, Hat noch jemand Probleme mit dem Corsa D OPC Getriebe? Das getriebe macht mittellaute Heulgeräusche. Das Geräusch wird mit...
Corsa D OPC Kaufentscheidung: Hallo, ich beabsichtige einen D OPC Facelift ab BJ12 zu kaufen, ich habe leider gelesen das er Motor Probleme mit den Pleul haben kann. Ist das...
Corsa D OPC, Overboost und ein paar andere Fragen: Hallo in die Runde! Habe mir einen gebrauchten Corsa D OPC mit dem A16LER Motor geholt und habe ein paar Fragen zu dem Auto: Scheinbar hat das...
Corsa d Z16ler ladedruckwerte: Hallo liebe commity Habe seit einge zeit nur probleme mit mein corsa d opc bj:2008 nach ein motorschaden und austausch motor. Zieht das auto nicht...
Corsa E OPC Nockenwelle Ablagerungen: Ich habe gestern Langeweile gehabt und mal reingeschaut. Für mich sieht das unnormal aus, wie ist Eure Meinung. Corsa E OPC 01/17 mit jetzt knapp...
