TURBO maniak
i want to ask you friends, can i use original XE flywheel in my LET engine. Are you know, wath is the XE and LET flywheel mass ? I know that when i use XE flywheel i need to change my clutch pressure plate, but this is no problem for me. I want my engine revs much more quickly.
My other question is when i mount XE inlet cam in my LET engine, what is cam wheel accurate position ? Is the cam position the same like normal LET cam position or one tooth advanced or retarded ?
Sorry for my bad English !!!
regards TONY
regards TONY
