Astra G coupe 2003 Z20LET, speedometer not working
Diskutiere Astra G coupe 2003 Z20LET, speedometer not working im other countries Forum im Bereich Technik; Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
Deaami
I have recently bought astra G coupe turbo, with Z20let and speedometer wasnt working at all.
I have changed LEFT side front hub with ABS sensor, but no help.
All light ABS, TC, Check engine ETC. are working properly, so no warning lights ON when car is running.
From generic tester i got fault codes:
-C0035 - power circuit of the left front outer sensor - no ecu
-P0500 - Vehicle speed sensor: dysfunction - present
So before going to opel dealer, for opcom reading and paying another 50e, does anybody (like me) suspect that ABS unit is faulty?
Let me say also, that i have checked all the connections on tachometer, radio, wires at wheels, ABS unit connection ETC. TWO blue/red wires in the radio connector are cut off and sealed with tape.
IF i unplug the ABS sensor connector in wheel hub, ABS light stays on, so i dont believe there is any issues on that area.
Thanks!
Astra G coupe 2003 Z20LET, speedometer not working - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
A14NEL and F17 remap: I have a combination of A14NEL engine and F17 gearbox in Meriva B. EDS offers a remap that would get about 165HP and 265Nm. The team from EDS says...
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
Nike Air Max 97 Plus may be a hybrid design: Proven above may be the Nike Focus Kobe ONE Protro, the best pair from the upcoming Nike Kobe 70's line. However the shoe is called a 70's...
It is imperative that you do follow all the safety: Riding a skateboard always has some risk associated with it. However, you can do your part to be responsible and to have fun with it at the same...
