Power wheel wtd, or help to make info req.
Diskutiere Power wheel wtd, or help to make info req. im International Corner Forum im Bereich Technik; Hi, I have a phase4 ecu, with no power wheel so is running low boost mode, I havethe 3pin connector wire from an old phase3 kit that goes from the...
Stu.Pink
I have a phase4 ecu, with no power wheel so is running low boost mode, I havethe 3pin connector wire from an old phase3 kit that goes from the power board to outside the ecu with the big black connector (red/black/brown wires), so assuming that is the same I do not need that bit, but does anyone have a spare wheel they don't want?
Alternatively, can anyone tell me what resistance I need over which pins so that I can simply wire it up for full power constantly?
Thanks.
BladeSTX
It's a voltage divider in 5 steps between 0 and 5V. You have a ground, a +5v supply and the signal to the powerwheel. Maybe someone can measure the voltages, but when signalwire is connected to the 5V you should have full power setting.
Stu.Pink
Thanks!! That is good enough for me.
So If i use a multimeter set to DC-V and measure against ground, I should find two 0v (the earth and the signal) and one at 5v.
If i then use the multimeter on ohms to check the resistance to earth of the two at 0v one should read 0ohms as it is ground and hopefully the other will be slightly higher?
So if i connect the 5v directly to the one that is a bit over 0ohms, and leave the other ground disconnected I will have full power?
I won't try this for a couple of days, in case anyone has anything to add.
Many thanks.
Power wheel wtd, or help to make info req. - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
