phase 3.5 kit...12psi !!!!
Diskutiere phase 3.5 kit...12psi !!!! im International Corner Forum im Bereich Technik; Hello all, I have a full 3.5 kit on my nova (corsa a) and I can not get it to boost over 12psi, I have tried the 4 settings on the power wheel...
David Dixon
England, County Durham.
Hello all,
I have a full 3.5 kit on my nova (corsa a) and I can not get it to boost over 12psi, I have tried the 4 settings on the power wheel and tried winding up the actuator and it doesn't make any differance!
Iv also fitted a uprated actuator from regal to match the kit!
Could it be the wastegate and if so why doesn't the powerwheel make any differance to the power and boost?
scotten
scotten
Dänemark
Hello.
Could it be your Wastegateseat thats is not okay.Maby you could chek it to be sure...Are the plasticpipes ( Actuator/boostvalve/blowoff and so on)for the boostcontrol connectet correctly?
0.82 Bar Boost is realy not much..
When I installt my powerwheel it dit not work too. Ist was one of the pins ( 1 of 3 ) in the round Connector for the powerwheel (not on the backside on the PW) who hat no contact. One of them where pushed back.
Sorry for my bad English..I did newer pay attension in the lessions.. :evil: :lol:
David Dixon
I have checked the pipes on all the conections and I have even tryed another amill valve but carn't find problem! maybe it is the wastgate!
If I should change the turbo which one should i get? I want to run around 20-22psi, Im going to buy steel rods and oistons but not sure which turbo.
Thanks for your help.
scotten
scotten
Dänemark
Hello, You could bye the EDS K26 or the Vmax K26,5/24. Schould be good for about 400 hp 8)
Are yor sure that the plasticpipes are placed correct on the Solenoid boostvalve? Ist the solenoid valve "klikking" when you turn the powerwheel from pos 1 and up..? Hmm, maby it ist your wastegateseat..
Miles
If you disconnect the pipe from the actuator so that the waste gate is held closed, and drive it very carefully whilst watching the boost gauge you'll soon see if your turbo can make more than the boost your currently getting. It should easily make 1.5 bar if its healthy, if you can do that your wastegate cant be too bad.
What overboost do you get?
Have a look at this thread for more suggestions
http://www.c20let-forum.com/viewtopic.php?t=10608&highlight=
phase 3.5 kit...12psi !!!! - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
