Onemanshow /Astra Z20LET .
Diskutiere Onemanshow /Astra Z20LET . im International Corner Forum im Bereich Technik; Underneat of the cylinder head ( valves side)
Onemanshow
Onemanshow
No space and time to waste , so lift it all up for a front removal
Tower build ( thanks to FTT /Sebastian )
Onemanshow
Onemanshow
FF2 is waiting (name for this "HOPE" new engine ) while checking for options
Onemanshow
Onemanshow
All the main engine parts are cleaned /labelled /stored in boxes with appropriate section
GTX 30 fully checked and inspected , video will come to see its condition
Onemanshow
Onemanshow
REmoving rods/pistons/crank (all gaskets were cleaned and in very good shape )
found some pistons parts on the bottom oil pane :
Now , let's be shock
My new computer wallpaper
Onemanshow
Onemanshow
3rd piston under the spark plug #3
If i can only knew what have cause this , i would be a very happy guy .
Onemanshow
Onemanshow
I have never Questionned KLASEN remaps , i always had those and NO problems .
I am trying to find out what could have cause this , and i am running out ideas .
This to avoid this to happen again
- Spark plugs too hot ? ( recommended by Klasen , and i am assuming other stage 5 or more are using them)
- 98 Fuel ? i always get the gaz from the same "cleaned" gas stations
- Faulty spark plug ?
- bad driving ? ( i wasn't pushing the car harder than my race agaisnt the Porsches )
- Un luck ?? ( i don't beleive that , everthing is happening for a reason )
- Injector(s) failure ? will get them checked /tested after running them in the new Test engine 02
Any ideas ? please throw them at me , PM , even if in German , i will use a translator or i will send them to a German speaker .
Christian
Onemanshow
Onemanshow
Got my parts from Main Engine 01 sand blasted before painting , those will later go on the final engine .
Onemanshow
Onemanshow
Duplicate , sorry .
Averell
Averell
Ruhrgebiet
Wow,
so much work to do - but you did well!
As I see, the turbocharger isn't damaged at all?
I can't believe the condition of the piston underneath - looks like a heavy cooling problem.
Steel rods and many other parts could be mounted again and that's good news.
Onemanshow
Onemanshow
Averell , i still have to open up the exaust side of the turbo , i need to check the blade/wheel and see if it is not damaged on the side , that could be the case .
Onemanshow /Astra Z20LET . - Ähnliche Themen
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Help: Losing oil and turbo power !!? (Astra PhaseII): Hi all you Z20LET experts out there ! Please give me some advice on this problem: Since I passed 60.000 km, the oil usage has increased...
EDS Phase II - first driving experiences and some questions: Hi All, Finally I got my Phase II installed at EDS - for almost two months I've been feeling like a kid waiting for christmas... After driving...
