Onemanshow /Astra Z20LET .
Diskutiere Onemanshow /Astra Z20LET . im International Corner Forum im Bereich Technik; http://youtu.be/kdj5FLc4A68
3rd piston under the spark plug #3
If i can only knew what have cause this , i would be a very happy guy .
What fuel supply you have? Fuel pump, catch tank and power supply?
It looks like a standard lean running damage.
Did you checked the fuel trim and O2 sensor in the ECU?
EGT and wide band you don't know? (at the damage)
Onemanshow
Onemanshow
Acki , thanks for your feedback
I am running Wallbroo and Pierburg + catchtank , uprated 12V power supply cables .
I have checked with Stephan and the bottom line is all this hapended because of Fuel .
My car stayed in Germany for a few days ( adjustments before remap) and of course i had Octane 98 when getting over there .
The car set up took a few days and the car had to be refill two or three times ( Octane 102 ) .
The spark plugs were also replaced and the NGK Irridium PFR6B were fitted before the dyno .
Mistake #1 was not having refill the car with 98 ( what is use here in France )
Mistake #2 the spark plugs were maybe not cold enough under the heat that day ( fuel quality lower than the 102 , long race at high speed the engine cylinder maybe got hotter due to the cylinder bore i was running 87.00mm , .... the spark plug electrode over heated and melted or broke ...
These are the only valid explanations i have at this time , maybe much colder spark plugs could have made me avoid this , but ... what can i do now
I learned my lesson , very expensive one .
Onemanshow
Onemanshow
Got the rest of the parts cleaned up , wrapped up , some oiled
I need to have the cylinder head fully checked just in case , all the sensor and parts have been removed and stored .
Onemanshow
Onemanshow
I am hoping the rod axle will be fine , i will have it professionally checked and all that ( balanced , rotated ... ) to see if they are still fine ( the one from cylinder #3)
I have removed the pistons ad struggled to get that one out , as you can see the axle is damaged
Bielles enlevées , mais pour le Piston percé , j en ai un peu bavé et j ai peur que l 'axe ne soit abimé , je verrai lors du controle des marques ...
sebi114
ist das normal das die kolben ,,so ausgewaschen" aussehen?
Onemanshow
Onemanshow
Ich reinigte gewaschen die Kolben oben auf dem beschädigten überprüfen und sehen, ob es wurde cliking Marken oder Punkte=
I cleaned washed the pistons top to check on the damaged and see if there was cliking marks or points
The damaged small end bush is only at the rod where the piston is melted?
Onemanshow
Onemanshow
The damaged on the rods happened when i forced the removal of the piston axle , it is only on surface and i think can be removed/cleanded .
Der beschädigte auf den Stangen passiert, wenn ich die Entfernung der Kolbenachse zwang, ist es nur an der Oberfläche, und ich denke kann entfernt / cleanded werden.
Onemanshow
Onemanshow
I drove a few kms today ( about 200kms) .
The Black AStra OPC is the OPC 160 but Z20LET swap , soon to be remapped (Stage 4,5)
The Vectra OPC is stock for now and will be remapped Soon as well .
Onemanshow /Astra Z20LET . - Ähnliche Themen
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Help: Losing oil and turbo power !!? (Astra PhaseII): Hi all you Z20LET experts out there ! Please give me some advice on this problem: Since I passed 60.000 km, the oil usage has increased...
EDS Phase II - first driving experiences and some questions: Hi All, Finally I got my Phase II installed at EDS - for almost two months I've been feeling like a kid waiting for christmas... After driving...
