Onemanshow
- Dabei seit
- 18.01.2012
- Beiträge
- 685
- Punkte Reaktionen
- 1
oh man that sucks hard
do you rebuild the engine or selling everything?
Hello
I haven't found anyone to give me a good price on the car ( for the parts spent on it )
I am rebuilding the car , i am just thinking about my bottom block that i don't want to change ( serial number) but i had 87mm pistons on it
If i buy a special ordre of that one replacement pistons and rings , i don't think that would do it because the block is Scratch and damaged , i would have to go 87.5 or more or 88mm pistons to keep my block
Another thing would be to add cylinder rooms inside my cylinder and re use standard bore size pistons , but i don't have a lot of informations and research about that process .
My last option is i can get another stock Z20LET bottom block and use it with Z20LEH pistons .
i will have to clean it , re do the oil jets , rebalance all the bottom ( crack/flywheel/.... )
The block should be around tomorrow with the pistons , i need to gather some infos on if i should machine the Z20LEH pistons head or not .
Then i need to have my cylinder to be checked and inspected ...
