Onemanshow /Astra Z20LET .
Diskutiere Onemanshow /Astra Z20LET . im International Corner Forum im Bereich Technik; Does anyone know what are the measures to start the engine the first time after a full rebuild ? When i did my engine before , an OPEL mechanic...
Onemanshow
Onemanshow
When i did my engine before , an OPEL mechanic guy helped me out ( he builded the engine ) and start the car by removing the plugs/ a couple of relays and some thing else , i don't know exactly what it was , so i am seeking for advices to get the oil up and all over before starting every thing .
Thanks
Onemanshow
Onemanshow
Hello!
A very, very nice work you did/do!!
So much new OEM parts, awesome!!!
I don´t know if you ever drive with your Coupe since you started the modification :wink: , but do you notify a diference with the swaybar on your rear axle??
I´m not shure to buy it......
Hey Raven
Sorry , i overlooked at your question
the rear lower anti roll bar would be a good purchase (in my humble opinion ) , i am not track racing my car but i do very fast driving and occasional "cornering "
My actuals suspensions are cheap and not good , before fitting the bar , on high speed , the car was not " well balanced " and depending on how fast i was going i could rub my rear arches .
Since i fitted the bar , my car is not a "chassis killer" but i can feel a different balance ( set to the hardest level) and i have that rear solid sensation ( only a sensation you must think) , but physically , my rear arches are not rubbing anymore , and i have not changed my hight adjustment on the coil over , there fore , in my opinion , for the price , it is a " must buy" item .
Raven
Raven
Ebenthal NÖ
Thank you!!
It makes my decision easyer :wink:
Well done till now and I hope you can finish your project as soon as possible without big troubles!!!
Acki
Acki
Lausitz
Thanks
The relays for the fuel pump I think was it.
Remove the plugs and disconnect the fuel injectors and the coils from the wiring harness.
Then crank the engine till you have oil pressure. Connect and install all - start the engine :)
Onemanshow
Onemanshow
BIG Thank's to you Sir .
Should all happening this week end .
Onemanshow
Onemanshow
Hello
a few pictures of a "long " week end .
Fitting the radiator and checking stuffs , it is really tight and the fact that i took the Z20LEH a/c hoses is not helping as i was thinking , i need to come up with some Z20LET again, i sold mine a long time ago ...
Onemanshow
Onemanshow
I was always wondering if there is spacial way of fitting theses, on my GT28 set up , i attached these to the radiator , but i don't even know if there are things to watch out for .
Onemanshow
Onemanshow
Custom made" heat dissiper" to tying to protect the cooling fan
It is really hard to come up with something really decent , and the space i have is not really helping at all
Onemanshow
Onemanshow
Here it is , thanks Acki on the last tips , i really appreciate it .
Here is a sneak peak for you all , a few distails to check but w few things to check/improve
http://youtu.be/GgVhGLnt4MU
Onemanshow
Onemanshow
Hello
Not a lot of news beside a couple of issues .
The car started fine and was running pretty stable except for an exhaust leak on the V band sections ( they have warped during the welding ...)
I am getting that fixed fixed and it pretty much ok .
Then i re assembled the front and after starting the car an oil leak started , i only had a very tiny leak on the "dash daq" connectors that i use for my oil return , before re fitting every thing , i checked one last time all the parts and was making sure they are securely fasten
i did fasten the oil return line faster .
it looks like it is leaking from the connector going on the oil "adaptor/unrestrictor"
I will take a look at it this week .
A few pictures
Onemanshow
Onemanshow
I have no pictures of the oil leak , i was under the car trying not to get burn and messy .
few others pics later :
Got a deal on these for my mate :
A bit cleaner :
Onemanshow
Onemanshow
My escape last week , i was running the car on idle for a while , i was starting to run out of gas .
I had a weird idea of just drive to the Gas Station to Refill ( no headlights/license plate / bumper /... ) was great , a 5kms drive being outlaw .
Getting some fuel
On the way back :
US corner lights
Standard16V
Tres Bien,Absolut NO! Repionts. Thats the Way how to build a Machine @ l,ame;-)
Onemanshow
Onemanshow
Today i found sometime to fix my exhaust leak and oil feed line .
A few pictures
She was very ready for a quick car wash
Bed time for "Stealth" :
bsh-brain
my respect you have its a beautiful car!!! something new? i missed some updates the last time :)
Onemanshow /Astra Z20LET . - Ähnliche Themen
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Help: Losing oil and turbo power !!? (Astra PhaseII): Hi all you Z20LET experts out there ! Please give me some advice on this problem: Since I passed 60.000 km, the oil usage has increased...
EDS Phase II - first driving experiences and some questions: Hi All, Finally I got my Phase II installed at EDS - for almost two months I've been feeling like a kid waiting for christmas... After driving...
