Onemanshow /Astra Z20LET .
Diskutiere Onemanshow /Astra Z20LET . im International Corner Forum im Bereich Technik; Sneak peak : That"s all for now I have to finish up the wiring , the radiators and A/C on the engine bay , the...
Onemanshow
Onemanshow
Sneak peak :
That"s all for now
I have to finish up the wiring , the radiators and A/C on the engine bay , the intercooler , battery , and all others little details that need to be take care of .
Great! How do you earn all this money? :D I think I have the wrong job... :(
Onemanshow
Onemanshow
Thanks for the comm Acki
No money , no big deal , it takes a lot of efforts , sacrifices and ... time , i f i had the money , this car would be on the streets already since ages ..
i like to learn and get some stuffs done myself when i have the chance , that's the best way of getting at least some satisfaction at some points ( like the cleaning aspect ) it looks like some people get more HP by getting dirtier cars ...
Thanks again , i hope the outcome will be great as well .
Onemanshow
Onemanshow
Last part of the brakes fitting yesterday afternoon :
I started with the left side first :
Pads and sensors on :
Facial :
Onemanshow
Onemanshow
By null at 2012-04-01
Onemanshow
Onemanshow
Hi there
A few updates
Everything was checking out fine except for some space i lost in the hood by making adjustments on the down pipe
I lost the small available space between the slim fan and the water radiator , i am working on it tonight to get this resolved
Regardless of the choices i have to move around my A/C hoses
Option 1 : Place the small Fan on the Water radiator ( in front of the A/C ) but i am afraid the cooling won't be enough but i will have greater space between the down pipe and the fan , i can add a heat shield also .
Option 2 : Keep the large fan in the back in front of the A/C compressor after moving the A/C hoses , but the larger fan will be closer to the down pipe as well .
Other than this , a few other minor adjustments , i should be ready to start the engine pretty soon .
I picked this for the solenoid ( amalvalve connector)
Top view:
Side
Really tight space available
Onemanshow
Onemanshow
I like your pictures with intake and exhaust manifold :D I made them for Stephan.
But your intake pipe to the TC I would change - or is the picture showing it not 100% correct?
http://www.klasen-motors.com/upload...c45d93e79fc8a8a2aab9d1a15f_dat1322465030.jpeg
There is the inner dia the same from pipe and TC inlet.
Thank you for your comment Acki
All i can say is well done and great job on the parts , i am not sure i get the point and understand what you mean by "intake pipe to the TC" i am a bit confused
can you circle or point the part so i can tell you if it was just a try out to see how it fits , thanks for your feedback .
Onemanshow
Onemanshow
i had some organization , moving things around to try to gain some space under the hood :
The A/C pipes have been heated with caution to be able to bent them and make some room for the fan
I have a bit more room
Onemanshow
Onemanshow
A guy on another forum tested the heat wrapping on his Z20LET , and it seems to have reduce the temperature going to the intake manifold , reason i decided to heat wrapped the whole piping , in case it also helps reducing heat .
THis is his test :
He had access to some very expensive device at his work to mesure the heat :
39 degres observed after driving at 120Km/h by 14degres celcius outside temperature .
Then he stopped , parked the car in his garage and opened the hood ( all in 3mns time) heat wrapped 3X the sensor on the intake .
After about a minute , engine running , bonnet closed , the temperature went to 42 degrees celcius
Onemanshow
Onemanshow
Once this test done , he wrapped up the whole piping
the bandage
dismounting all clamps to gain access
Right pipping side :
Once done , almost dark
Next day ( Same conditions , 120 km/h same road , same external weather and temp conditions ) 3mns parking time a stick the sensor to check :
Same place , same length with 13.5 degree celcius
result
Onemanshow
Onemanshow
Finally , he dropped about 10 / 11 degree celcius by wrapping and protecting the whole complete pipping .
i will see what it does on mine once finished .
Prior , on my previous set up , i had my Klasen exhaust manifold ceramic threated , it was pretty amasing :
Then later i used the FTT wrap bands to cover the manifold , but i haven't tested it , i sold the GT2871, my new GT30 also and upgraded to the GTX and the new KLasen stuffs .
The pipe looks smaller than the inlet of the tc.
Or is the hose only bigger than on the picture?
Onemanshow
Onemanshow
Hi Acki
Thanks once again for your feedback
Are you talking about the Hose reducer between the Turbo inlet section and the pipe that goes towards the MAF sensor ?
If yes , i have a Silicon hose joiner that is a Reducer from 90mm( Maf side) to 110mm (turbo side) , i don't know if you was talking about this pipe or something else ?
Onemanshow
Onemanshow
Yes Acki , there is no reduction or no more restriction , maybe the bandage gave you that impression , because i used some heat wrapped on it .
But thanks Acki for bringing that attention .
Onemanshow
Onemanshow
Acki , it looks more like this ( with the heat wrapped in addition )
Onemanshow /Astra Z20LET . - Ähnliche Themen
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Help: Losing oil and turbo power !!? (Astra PhaseII): Hi all you Z20LET experts out there ! Please give me some advice on this problem: Since I passed 60.000 km, the oil usage has increased...
EDS Phase II - first driving experiences and some questions: Hi All, Finally I got my Phase II installed at EDS - for almost two months I've been feeling like a kid waiting for christmas... After driving...
