F28 second gear loss
Diskutiere F28 second gear loss im Antrieb Forum im Bereich Technik; Hi, yesterday i broken my F28 second gear, and when i want to shift the noise is kkrrrrrrrrrrrrrrrrrrrr, i can shift second only in 3000rpm. I...
TURBO maniak
BULGARIA
yesterday i broken my F28 second gear, and when i want to shift the noise is kkrrrrrrrrrrrrrrrrrrrr, i can shift second only in 3000rpm. I think my problem is second gear sync, and i want to ask you can i use synchronizator of any other gearbox (F20,F18,....or other no Opel gearbox). If i can't can you tell me what is price to new second gear sync ?
Sorry for bad English !!!
regards TONY
J
Joe
Tony,
sorry for the bad news, but you can't use any other GM synchro rings and you need a hydraulic press which should be able to deliver a minimum of 15 tons of pressure to exchange the 1. and 2. gear rings. Using heat or any other methods will end up with a bent or otherwise damaged gear axis !!!
Try to get in contact with
www.dorfbrunnen-garage.ch
They are worldwide the only distributor for F28 spare parts and can , if requested, revise your F28 gear box, power steering & 4x4 transfer box .
F28 second gear loss - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
V2000 Digital LCD Tacho: Hello guys I am from hungary, that is why i speak English, sorry for that :/ I have a V2000 digital tacho, perfect condition, everything works...
