Ash can you give me some information on the k26 turbo
Diskutiere Ash can you give me some information on the k26 turbo im International Corner Forum im Bereich Technik; is the k26 suitable for a phase 3.5 engine, what revs does it start to bring the power in and what revs do you get maximum boost at
tabs
ASH
ASH
Hi !
The first Phase 3.5 engine was used with our KKK K26 Hybrid Charger !
You get the max. boost between 3000-4000 RPM and the regulated boost is stabil up to the rev limiter with low backpressure to the engine !!
regards ASH
tabs
ITS OK IF ITS AROUND 300 REVS BUT I AHVE BEEN TOLD BY A FEW PEOPLE THAT HAVE THE TURBO THAT IT IS MORE AROUND 4000 REVS
GSI-TURBO
I hope Arno can also give an answer about the ignition settings in the Ph3,5.
As i can see it is retarded a lot.
tabs
mate how do you know its retarded what happens to the cars performance
rodgerq
tabs, when the ignition is retarded the car feels sluggish. can be pretty bad depending on how retarded the ignition is. maybe your knock sensor is picking somethin up and pulling back the ignition for safety.
rodgerq
GSI-TURBO
No had a look to the ingintion tables in the ph 3,5. Because my car didn't react quick when i pressed the throttle.
If i can make a nive program to edit the tables then maybe i will keep the phase 3,5 otherwise i will install a DTA system.
Ash can you give me some information on the k26 turbo - Ähnliche Themen
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
Why is my engine retarding ignition?: Hi guys, please help me with my Zafira OPC Z20LEH. Why is my engine retarding ignition? I have always felt i was missing top end power so i...
Any experiences K29/K26 turbo?: Hello! Now finally my rebuild of C20LET is nearly ready except turbocharger. Now I need some advise from you...I have been thinking 2 options...
