Why is my engine retarding ignition?
Diskutiere Why is my engine retarding ignition? im other countries Forum im Bereich Technik; Hi guys, please help me with my Zafira OPC Z20LEH. Why is my engine retarding ignition? I have always felt i was missing top end power so i...
Z
Zaffy_Boy
I have always felt i was missing top end power so i logged my car with opcom (from ebay), and found out the ecu is retarding ignition.
This was on the EDS IPF 315ps map, i then uploaded the original map, and it is also retarding.
On 3 gear pull, knockcontrol becomes active at about 4300 rpm, 0,9 bar boost and retards ignition upto 12 degrees all the way to redline.
Outside temp was 4 degrees, inlet temp was max 27 degrees.
Car is running on Shell V-power 99 oct
My current setup:
Vectra C air intake pipe
Cdti airbox, KN filter
AET hybrid turbo
EDS front mountet intercooler
Custom powerpipe
EDS intake cam
EDS tophat
EDS turbo downpipe
Cobra 63mm sportskat
Milltek 63mm exhaust system
NGK iridium plugs (new)
Does anybody have any suggestions?
Thanx
Kasper from Denmark
24-7
24-7
neben Köln
Any DTC in ECU exisitng?
Fuel pump /fuel pressure.
Or check ignition coil module.
Any display for AFR in your car? can you log the lambda sensor?
Z
Zaffy_Boy
knock control sensor ok?
Hi, i can see the knocksensor value in volts, in the opcom log.
It start at 4V and goes up to 65V along with the rpm.
I was going to change the knocksensor, but spoke to the main opel dealer, they have never sold one before!?
I dont want to spend money on parts if iam not sure they are broken.
I dont know what the normal knock value are, if anyone know, please tell me...
Z
Zaffy_Boy
Hi there is no errorcodes present, if that what you mean by DTC.
I havent checked the fuel pressure, but i belive its a bit on the rich side.
Can it cause knock if its running to rich??
The log reads, on full load the lambda reads 840-930 mv.
How can i check the ignition coil module?
Why is my engine retarding ignition? - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
A14NEL and F17 remap: I have a combination of A14NEL engine and F17 gearbox in Meriva B. EDS offers a remap that would get about 165HP and 265Nm. The team from EDS says...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
It is imperative that you do follow all the safety: Riding a skateboard always has some risk associated with it. However, you can do your part to be responsible and to have fun with it at the same...
Crystal Pilsner glasses: If You Need A Gift For A NFL Fan Shop Here Officially licensed NFL merchandise available with team logos from Jerseys NFL.com - NFL merchandise...
