That's a good question. In the German "manual" of the Kadett-E there is no 20XE - you can only find the C20XE and the 20XEJ both with 150hp, the C20XE with and the 20XEJ without KAT. Maybe the 20XE and the 20XEJ are the same and the 20XEJ was said to have "only" 150hp because of the german insurance system of that time - but I don't know if that's true or not.
Why? It allows closed loop running on part throttle/idle. It's only required by a cat because unburnt fuel damages them. Having a lambda sensor doesn't require a cat though.
nope.... The only thing i have heard is that the 20XE should have 156 BHP and the 20XEJ should have 150 along with the C20XE. But I dont know the explanation or the technical differences... :-(
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku.
I'm A owner Corsa D A16LEL with few mods:
- wydech prosty...
Standard Extremes Ruckeln beim Kaltstart: Hallo zusammen, hatte in der Vergangenheit mal öfters Probleme mit ruckelndem Motor beim Kaltstart. Seit 2 Tagen aber extrem, sodass auch der...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help.
I have recently bought astra G coupe turbo, with Z20let...
Nike Air Max 97 Plus may be a hybrid design: Proven above may be the Nike Focus Kobe ONE Protro, the best pair from the upcoming Nike Kobe 70's line. However the shoe is called a 70's...
