My Kadett GT30R
Diskutiere My Kadett GT30R im International Corner Forum im Bereich Technik; What would Borat say!? :D It´s NIIIICE!
der gallier
der gallier
wallenhorst
:shock: mein krümmer!!! :shock:
dachte meiner währ ein einzelstück!!! :lol:
sehr schönes auto!!!
hätte auch gern wider einen kadett
kadett21
kadett21
Dresden
Du hast jetz nen bösen A Corsa mit noch bissl mehr dampf :lol:
@Franck:i drive the same wheels on my Vectra B!Nice wheels
c20xeturboastra
c20xeturboastra
Nice!!!!!! Beuty, Dezent Car and the engine amazing
Franck
Franck
Paris
I received my tires slick for Bitburg :D
Tires
Hoosier 17310
D.O.T. DRAG RADIALS
225/5OR-15
der gallier
der gallier
wallenhorst
hey geil!!
was für einen aussendurchmesser haben die und was kostet so ne pelle??
sehr gut :twisted:
Franck
Franck
Paris
Some news about my oil leak which makes me mad
After changing the gasket of the crankshaft, it still leaks.
And it's not easy to find where it comes from with the flywheel
And then I thought about this oil screw
So dismantling again ...
And it still leaks
So I putted down the gearbox and turned on the engine without the gearbox.
I guess it leaks from the bearing of the crankshaft or from the sump gasket.
The picture is the engine which turned on 5 min
The picture is the engine which turned 10 min
The sump gasket was changed after the 2nd gasket of crankshaft
And a video just for the fun
http://gsiturbo.free.fr/gsi-turbo/image/ma-kadett/kadett-91/2008-05-15/MVI_7674.AVI
Samy
Samy
Borken
Did you use enough sealing compound on the last bearing cap? It even looks like you don't use any if thats the case it will always leak there.
TiCar
TiCar
Stuttgart
Hier ist die Amtssprache Deut oder Englisch, fertig! Akzeptieren oder lassen!
Gsi 16v Turbo
Gsi 16v Turbo
+1.000
Frank at this point it's necesary to use sealing compound.
My Kadett GT30R
My Kadett GT30R - Ähnliche Themen
Klasen Motors: Hello I would to share my experience : On October 2010 , i had my car remapped at KLASEN MOTORS with my first set up (I am not a...
Any experiences K29/K26 turbo?: Hello! Now finally my rebuild of C20LET is nearly ready except turbocharger. Now I need some advise from you...I have been thinking 2 options...
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Astra Gsi Turbo-dyno: Ηello from Greece to all of you.This is my Astra Gsi Turbo. It's a Gsi 16v with full conversion to C20LET 6 speed FWD. Specs: ENGINE C20LET...
684PS C20LET: I've dynoed my C20LET engine with these specs: Original crankshaft (Kurbelwelle) Verdi connecting rods (pleuel) Wössner 86.50mm pistons ARP main...
