My Kadett GT30R
Diskutiere My Kadett GT30R im International Corner Forum im Bereich Technik; How many hp make this machine?
Gsi 16v Turbo
Gsi 16v Turbo
Nice work Franck.Did you finish your project?
Franck
Franck
Paris
I hope soon finished.
My kadett is at Klasen for the setup of the motronic.
Gsi 16v Turbo
Gsi 16v Turbo
Franch the Klasen-Motors is at Germany.So did you drive your car to Germany?
You are going to use thn Motronic?The most power i have ever seen with the Motronic is 360ps.
I hope to get much more than 360ps. :wink:
Gsi 16v Turbo
Gsi 16v Turbo
Very nice.420ps!
I didn't say that it isn't possible to make that power with Motronic.I said that i have never seen C20LET with Motronic with more than 360ps.So you can get at least 420ps with the 2.7. :D
Gsi 16v Turbo
Gsi 16v Turbo
Αll theese dyno with 2.7!!!!!????Amazing!
Can i ask something?When you use the 2.7,the AFM and the wiring remain?I thing that Vmax E30 doesn't has the AFM.Or you use only the ECU?
I never thought that the 2.7 is capable for such power.....
Nice work. :D
Kadett GT
très bon travaille, maitenant quelqu'uns doivent s'habiller chaud franck!!!! :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
FB66Turbo
Glückwunsch zur der leistung.
Ab 5500U/min dreht das Teil ganz schön auf.
@DD
Unter 4000-4500U/min wenig bis keine Power. Kann man da nichts unternehmen? Hat es was mit Umfeld zutun ,weil daß ist jetzt das 2 te Kadett mit GT30 und über 430PS die Untenrum nichts drauf haben. :roll:
Wenn ich beim rausbeschleunigen denke, ist das ja ein Alptraum bis die Leistung kommt.
www.corsafan.de
www.corsafan.de
Niedersachsen
I like it!!
My Kadett GT30R
My Kadett GT30R - Ähnliche Themen
Klasen Motors: Hello I would to share my experience : On October 2010 , i had my car remapped at KLASEN MOTORS with my first set up (I am not a...
Any experiences K29/K26 turbo?: Hello! Now finally my rebuild of C20LET is nearly ready except turbocharger. Now I need some advise from you...I have been thinking 2 options...
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Astra Gsi Turbo-dyno: Ηello from Greece to all of you.This is my Astra Gsi Turbo. It's a Gsi 16v with full conversion to C20LET 6 speed FWD. Specs: ENGINE C20LET...
684PS C20LET: I've dynoed my C20LET engine with these specs: Original crankshaft (Kurbelwelle) Verdi connecting rods (pleuel) Wössner 86.50mm pistons ARP main...
