Info flywheel C20LET... please
Diskutiere Info flywheel C20LET... please im International Corner Forum im Bereich Technik; I want revision of the C20LET then to put it on an Astra GSi Mk3. I have read in other thread that replacing the camshaft of the aspiration of...
I
Ienea
I have read in other thread that replacing the camshaft of the aspiration of the C20XE on the C20LET, I have several power.
Will I have carburation problems replaced once or it will be all OK? :?
I want also to balance each other the crankshaft with the flywheel and the clutch.
The flywheel of the C20LET is certainly heavier than the flywheel of the C20XE.
The Astra will be a front traction, not 4X4, not to have problems, of how much I have to lighten the flywheel of the C20LET?
I must do it as light as that of the C20XE?
However I do not know what he weighs, and dismantling it now does not seem the case to me. :shock:
Tank's and sorry for my bad English. (I'm Italian) :p
Info flywheel C20LET... please - Ähnliche Themen
A14NEL and F17 remap: I have a combination of A14NEL engine and F17 gearbox in Meriva B. EDS offers a remap that would get about 165HP and 265Nm. The team from EDS says...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
It is imperative that you do follow all the safety: Riding a skateboard always has some risk associated with it. However, you can do your part to be responsible and to have fun with it at the same...
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
Nike Air Max 97 Plus may be a hybrid design: Proven above may be the Nike Focus Kobe ONE Protro, the best pair from the upcoming Nike Kobe 70's line. However the shoe is called a 70's...
