External Wastegates?
Diskutiere External Wastegates? im International Corner Forum im Bereich Technik; At what state of engine tune would you change the turbo to one that runs and external wastegate? is it worth it and why? Ta.
Allen Mead
Ta.
rds
Turbonetics in the States recommend an external wastegate if you intend to run 20 psi+ boost. External wastegate gives far superior boost control and also helps turbo spool up quicker! If i can mod my turbo to accept one i may fit one :wink:
External Wastegates? - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
Nike Air Max 97 Plus may be a hybrid design: Proven above may be the Nike Focus Kobe ONE Protro, the best pair from the upcoming Nike Kobe 70's line. However the shoe is called a 70's...
