astra h gtc turbo fell p1106
Diskutiere astra h gtc turbo fell p1106 im Z20LET | LEH | LEL | LER | NET Forum im Bereich Technik; hallo hilfeee))) :roll: i mine auto hat ein nue opc leh lad und5500rpm laddryk goes down bis 0.25 un fell code com und der box goes in...
O
opelmandk
goes down bis 0.25 un fell code com und der box goes in emergency mode:shock: :cry: :evil: :roll: :( :cry:
  • astra h gtc turbo fell p1106
OPC2013
OPC2013
Burgdorf(bei Hannover)
Så det handler om fejl.
P1106 Boost Pressure Sensor Sammenligning
P1106 ladetryk signalet er ikke inden for rammerne
P1106 Boost trykstyring fejl
Jeg havde engang ...
gange et link her ...
http://www.astra4ever.net/opel-kennt-den-fehler-nicht-t32252-s25.html
Jeg ved ikke, hvad fase du skal hen, eller hvis du har et generelt på det.
Jeg blev sat under den høje temperatur udstødning af fejl var Wech og kom aldrig tilbage ...
So it is about the errors.
P1106 Boost Pressure Sensor Comparison
P1106 boost pressure signal is not within limits
P1106 Boost pressure control error
I once had ...
times a link here ...
I do not know what phase you are going or if thou hast a general on it.
I was put under the high temperature exhaust of errors was wech and never came back ...
O
opelmandk
I once had ...
danke ich will get my remab tjekedd))
så you mean its get to hig temptur??
OPC2013
OPC2013
ja, det er bestemt ved emission temperatur. Det var år siden, da mig og de fejl 3.
du har en fase du skal hen på det, eller endda originale software?
Samy
Samy
Borken
This error code says that your boost is too high. There are two possible reasons for it.
1. Your turbosystem has a problem maybe the wastegate is stuck or the hose on the wastegate actuator isn't connected.
2. If you run a tuning software and the error occurs just after it the mappings could be and often be the problem. Faulty diagnose mappings or wrong timing mappings.
O
opelmandk
ok thx for the replay i vil tjek those things)=)
astra h gtc turbo fell p1106 - Ähnliche Themen
Astra H GTC 2.0 Turbo Z20LER abzugeben: Hi zusammen, ich überlege meinen Astra H GTC 2.0 Turbo (Z20LER) Bj. 2006 abzugeben. Mittlerweile hat er zirka 180.000 km auf der Uhr, daher kann...
Astra H GTC Turbo 200 PS ruckelt plözlich bei Last: Hallo Bin der Ralf , im Januar habe ich mir meinen Traumwagen zum Geburtstag gekauft einen Astra H GTC Turbo 200PS er hat nie mucken...
Opel Astra H 2.0 Turbo - Werkstattempfehlung in Region Nürnberg: Opel Astra H 2.0 Turbo Ölverlust - Werkstattempfehlung in Region Nürnberg Hallo zusammen, bin neu hier und freue mich hier zu sein :-) Ich bin...
