3 layer head gasket question.....
Diskutiere 3 layer head gasket question..... im International Corner Forum im Bereich Technik; Hi Friends, I have one question.......can i use 3 layer head gasket on my C20LET engine because original gasket is destroyed and i want to put...
TURBO maniak
BULGARIA
Hi Friends,
I have one question.......can i use 3 layer head gasket on my C20LET engine because original gasket is destroyed and i want to put stronger gasket . Layer one is cooper with thickness 0.3mm, second layer is CrNi sheet with thickness 2mm, and third layer is cooper with thickness 0.3mm.
Thanks for replys
Regards
TONY
  • 3 layer head gasket question.....
TURBO maniak
BULGARIA
I can't use Z20LET gasket because my COSCAST head is surface machined two times, first time 0.4mm and now second time 0.06mm, and if i use original gasket compression ratio will be very high.
Wath is Z20LET gasket thickness ?
ASH
ASH
Hi !
Forget this fairytale , everthing below 1.0mm chimmed head is OK !
With a only 0.5mm chimmed head and a 2.5mm thick gasket , your car will be slowing down and you loose power !
Use the Z20LET gasket , its alldayuseproof , you will never have any problems with water leakedge , most of all the flat copper-steel-copper head gasket solutions are good for short living high power solutions , but the allday use with its high frequent hot-cold cycle will cause a water leakegde by the time !
If you wanna really reduce your compression rate , take the 2 middle parts of a Z20LET gasket and make a tower out of 2 , than your compression rate will be massive reduced and you are save !
regards ASH
TURBO maniak
BULGARIA
Hi ASH,
Can you tell me price for Z20LET head gasket and gasket thickness.
In future i want to upgrade my engine with Phase 3(3.5), XE inlet cam, and K24 or K26 kompressor wheel.
regards TONY
ASH
ASH
Hi !
Its depending how your GM dealer likes you , normally the gasket costs like 20 EUR !
The Thickness ist 1.3mm !
regards ASH
TURBO maniak
BULGARIA
Opel dealers in Bulgaria don't offer this gasket because in our country there isn't Z20LET cars :( . If i offer this gasket to my Opel dealer, i must wait one mount for delivery.
Do you know any internet sites that can offer me this head gasket ?
regards TONY
3 layer head gasket question..... - Ähnliche Themen
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Quarter panels: Hi, I am new here. My name is Maartje and I live in Holland, I drive a Opel astra GSi 2.0 16v . I have a question, I'll hope that it's okay...
EDS phase3 problem: It is not working any more. It worked just fine for a while with adjustable pressure control. With switch on step 1 the loading up pressure was...
Z20LET engine misfire and hesitation under high boost at hig: Hi guys, I really need help... I am desperate! Please be patient to read this long post and feel free to post any tips/advice on possible...
