Onemanshow /Astra Z20LET .
Diskutiere Onemanshow /Astra Z20LET . im International Corner Forum im Bereich Technik; Huhu, You are mad! ;-)
  • Onemanshow /Astra Z20LET .
There is no other word to say as AWESOME!!!!
Very beautyful work what you do, man!!
Onemanshow
Onemanshow
Thank you , the parts i buy them from the states for opel cars , not to fit on mine ( the CARRILLO ) mine are getting the Pauters .
Pistons to come soon , the CARRILLO PRO SA - A are 562g / each .
Thank you
@Onemannshow: Tell me what fuel system or in fact what pump do you use in your Astra?
I'm asking because I want to change the turbocharger, Intake and injectors to get approximately 280-300BHP.
And I want to use the aeromotive stealth 340 version 11142, so what do you think?
Onemanshow
Onemanshow
Hello Averell
I am far away from being an expert but i think on your setup it will be good .
At that power range , i was using ( before) an Uprated WallBroo internal fuel pump with 470cc injectors ( Z20LEH) .
For the current set up i had until my engine failure , i still have the Internal Uprated Walbro + Peirburg XXL + catch tank ( Damian install) and 630 cc injectors .
I just sold my injectors and getting new bigger injectors but keeping the Walbro/Pierburg .
Bottom line is in my humble opinion , you can't go wrong with AEROMOTIVE Stealth 340 as oposed to an OEM fuel pump , Go for it .
I will and I try to get one direct from USA because they're much cheaper as in germany.
I have ordered the pump today and it costs 138,- Euros including shipping from United States.
Maybe I have to pay sales taxes for the pump, but then it's still cheaper as in UK or GER.
Onemanshow
Onemanshow
Yes true , i order most of my stuffs from the states , have them delivered to my house there, and send it to me , that way no taxes, duties or extra fees .
Next step is the turbocharger and I want to order it direct from courtney sport.
By the actual exchange rate the charger should be ~ 200 Euros cheaper as in GER and casket set is included!
I prefer the standart LEH-Charger without special bearing or else.
My current LET-Charger has the special bearing but nevertheless it's running out of range and loses oil.
Maybe it depends on boost level up to 1.52 bar.
So I want to swap the charger and decrease boost level for more reliability.
I also swap the injectors (470 ccm), the pump, LEH-hoses from filter to LEH-Sensor housing and the sensor housing itself.
Onemanshow
Onemanshow
Great program , i can get you some stuffs in you want , i can give you a quote on PM
here are some parts i am selling around here from a friend of mine working at an OPEL Dealership .
Turbos /MAF/Injectors /Balancer shaft removal /Z20LEH oil pumps and so on , but no great deal on Z20LEH pistons (around 800€)
Onemanshow
Onemanshow
Hi There
My 630'cc being sold , i needed to get some replacement ones :
870cc EV1
Also getting a new internal fuel pump to replace my Walbro 255 .
@ Averell
The Stealth 340 pump seem excellent
http://realstreetperformance.com/st...ph-in-tank-fuel-pump-with-setup-kit-2610.html
Check the benmark tests and results as oposed to some others intake/inline fuel pumps
http://realstreetperformance.com/store/pages/fuel-pump-comparison-test-5.html
I have the stealth 340 and am very happy with her​​! fits great in the astra and promotes enough for more power! less a part that needs to be expanded later with more power again!
@bsh-brain: How have you realized the connection to the pump into the pot?
beyond the original spliceless. I removed the cable from the connector pins in the big cable and soldered there! fits reasonably
german ^^ über die originalen verbindungsstellen . ich habe die kabel aus den pins im stecker entfernt und das große kabel dort aufgelötet! passt einigermaßen
Onemanshow
Onemanshow
My friend finished swapped his Manta with a 3L Engine , took it on the road last night against the Vectra OPC (Stock) the Astra H OPC (Klasen Remap)
Engine bay and hood after some cleaning :
Night pics
Onemanshow /Astra Z20LET . - Ähnliche Themen
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Help: Losing oil and turbo power !!? (Astra PhaseII): Hi all you Z20LET experts out there ! Please give me some advice on this problem: Since I passed 60.000 km, the oil usage has increased...
EDS Phase II - first driving experiences and some questions: Hi All, Finally I got my Phase II installed at EDS - for almost two months I've been feeling like a kid waiting for christmas... After driving...
