Onemanshow /Astra Z20LET .
Diskutiere Onemanshow /Astra Z20LET . im other countries Forum im Bereich Technik; After a couple of races The gearbox stick was coming unloose , he had issues switching the gears , this will be fix next week . Bad races due to...
Onemanshow
Onemanshow
Nothing special going on .
Got my Internal fuel pump upgrade ( the second one sold to a friend here )
Also got my New pistons for my rods , i will have the valve clearance check and align them like the previous OMEGA for the pocket valves according the cams lift .
Onemanshow
Onemanshow
Next before the fitting , my crank will go to Vmax for treatment , then a couple of adjustable Ftt verniers and i will be good to go for the re assembly
Will go full ceramic coated all the pipping as well .
Standard16V
Why did you install the Pistons?Next Stage with more Pressure?:)
Onemanshow
Onemanshow
Hello
Reason why i am changing is on Page 28, i couldn't find the same Omega Forged pistons and the Z20LEH pistons offers i had was way more expensive than any other pistons i could access .
i don't know what type of fuel or Boost pressure i will be running
Onemanshow
Onemanshow
New Aeromotive Fuel Pump Fitted .
Pistons /Rods /Bloc will be machine (oil jet squitters fitted again , original bloc serial number engraved to the new one that will be use .
Things that will be done that were not done on the previous build :
Engine ration check and calculate according the pistons specs and other parts (will check differents head gasket sizes )
Crank nitrurated before full balancing as always , and other little details around to improve cooling and reliability ...
Pistons Slide :
http://www.youtube.com/watch?v=8TR8QVlDpww&feature=share&list=UU108Ak_DfUdBNve-5fKkUpQ
I also fitted another Astra g Clock for the Rev section ( Thanks to Damian for the Tip )
http://youtu.be/8fufVuk7yKA
Onemanshow
Onemanshow
Hello
Has anyone here by any chance have feedback or tips on fitting an water/Meth injection spray system on Astra G or H .
I saw that Courtenay just did it with their latest GTX Build , this reduce the internal engine temperature , any ideas on a fitting kit like the Aquamist stuff ....
Spare Wheel Well with Swirl Pot, Pierburg High Pressure Pump, Aquamist Pump and Methanol Tank
Laser Cut Acrylic Spare Wheel Well Cover
GTdriver
GTdriver
Hi mate,
there are several ways to mount an Water Injection. I used the Snow Perfomance Stage2. Its a progressive controller which add water/meth depending on boost. You can lower your EGT which an right choosen nozzle nearly 100° !! The nozzle sould be located near the the Throttlebody (arround 10ccm to 15cm before).
Here you can see the controller....for max. 1.7bar Boost pressure
http://img3.fotos-hochladen.net/uploads/file0454ecm1ljwpg.jpg
You set an start point and an finish point from the injection depending on boost. If it is properly mapped you can see good benefits, not a lot more hp, but an safer engine, because engine temperature lower significant!
In Astra G/H you must use the system in the rear, because i think you have not enough space to mount the fluidbottle in the enginebay.
Regards
GTdriver
Onemanshow
Onemanshow
Thank 's a lot GT Driver
It is nice of you taking your time to answer and comment .
I know , i am not trying to obtain some more power , but as you stated "safer" and better cooling by lowering the combustion temps .
By anychance do you have some ideas or feedback on the systems from Aquamist ?
it looks like courtenay used that brand on the astra H on the picture above , but few peoples all over the world are running that brand also on Evo, Focus RS , Audi's ....
What is your opinion on them ? http://www.aquamist-direct.com
GTdriver
GTdriver
Hi there,
no problem, i did a lot research over the years because i like the water injection a lot. All systems work well, there are higher priced systems which have some advantages, but only usefull if you have a real racecar. Take a look at Snow Perfomance. very good support here in Germany. Price is also ok!
Have a look here mate, very good explanation!
http://www.youtube.com/watch?v=NFU6KrSOe8U
Onemanshow
Onemanshow
GT Driver , cool thanks for sharing
Top Man .
GTdriver
GTdriver
Thanks mate ;)
wooza
wooza
Bünde
Hey,
Niiiiiice...i envy your speedometer...im searching for an OPC1 Speedometer like an half-year or smth...btw is it Plug and Play? Just replacing?
greetz
w00za
Onemanshow
Onemanshow
Hello Nils
yes , plug and play , my mate might have another one for sale , PM me if you want me to ask him if you can't get one there .
Onemanshow
Onemanshow
Hello
If some one is interested i have a few parts for sale :
Crankshaft Z20LEx
Worked on (***** + Polished)
Balanced
P.S Need to be balanced with your mobile equipment .
PM me if interested (Any other parts please ask )
Also have a Z20LET 86K Kms block / other accessories ...
Onemanshow
Onemanshow
Hello
Change of plan and will try something different , atuals parts for sale , pistons and ZLET block sold .
Will see how it goes and will keep you posted .
Onemanshow
Onemanshow
Hello
After a well sunny afternoon from the Dyno Day ( pictures on these links , try any )
random pictures (messy) few videos later
http://astra-coupe.be/modules.php?name=Forums&file=viewtopic&t=26449
http://forum.blitz-gsi.com/viewtopic.php?t=36449
http://club-opc-france.xooit.com/t6650-Klasen-Dyno-Day-4-MAI-2013.htm
Met with Nils "Wooza" , ex Red Devil owner ( sorry i forgot your first name) , Acki and some other great people.
P.S : Standard16V is a" special artist" , thank you for the gift from STEALTH DEV...
Special thanks to my old buddies Lars/Sead/Damian
Onemanshow /Astra Z20LET . - Ähnliche Themen
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
Help: Losing oil and turbo power !!? (Astra PhaseII): Hi all you Z20LET experts out there ! Please give me some advice on this problem: Since I passed 60.000 km, the oil usage has increased...
EDS Phase II - first driving experiences and some questions: Hi All, Finally I got my Phase II installed at EDS - for almost two months I've been feeling like a kid waiting for christmas... After driving...
