Phase 2 problems
Diskutiere Phase 2 problems im International Corner Forum im Bereich Technik; Hi Guys, I have Phase 2 fitted to my Cavalier turbo with a custom intercooler. I also have a boost controller which allows me to switch between...
Tris
UK
Hi Guys,
I have Phase 2 fitted to my Cavalier turbo with a custom intercooler. I also have a boost controller which allows me to switch between 0.7bar or 1bar boost. When running 1bar and I accelerate, the ecu light comes on and stores code 113, boost control out of range. Does the phase chip remove the boost limit or simply increase it? I thought 1bar was the right boost for Phase 2.
Also, the Phase 2 chips had Phase 1 written on them. I was informed by the distributor that Phase 2 uses the same chips as Phase 1 with the addition of the 3.5bar FPR and an Intercooler. Is this right or could it be the cause of my problems?
Thanks for your help!
Tris
:D
ASH
ASH
Hi Tris !
first one simple question : Who was your distibutor ?
Perhaps they only swapped the chips , but the complete engine diagnose programming at the EDS-phase1 and 2 are totally diffrent !
You must get the EDS Phase-2 chips , then it works !
Please contact your local dealer and get the right chip from him for free !
Also , when you use an external boost controler up to 1.1 bar , your fuel pressussure MUST me at minimum 3.5 bar with the phase-2 chip !°
regards ASH
Tris
UK
Hi Ash,
Thanks for your reply. I got the chips through RBX Motorsport who got them from Regal Autosport. When the chips were fitted and it was realised that they stated phase 1, Regal were contacted and said the chip was right, it was the uprated FPR and intercooler that made the kit phase 2.
I will contact Regal and let you know how I get on. Thanks again for your help.
Tris :D
W
Wallace_Perf
Hi Tris,
As Arno has stated, the chips for the phase one and two are totally different regarding boost levels and fueling.
If you are struggling to get hold of these quickly, I have phase 2 kits in stock and I'd be happy to swap those chips with you if need be and I'll then sort out the problems this end.
Let me know!
Regards
Gavin Wallace
PS - ASH, this forum is great, we just need to attract more people!
Tris
UK
Hi Gav,
Thanks mate. I haven't heard anything back from them yet so if I don't hear soon, I will take you up on your very kind offer. It makes me wonder if they have done this to other people aswell :(
Tris
Mel
Tris,l I had heard also that the phase 1 and 2 chips were the same . it wasn't till I contacted Gavin when I purchased my chips,that I discovered different. It makes u wonder who started the myth, and for what reason.
Hmmmmm?
Richie
Looking at everything thats been said it appears you have the Phase I chips Tris. When the ECU sees you going over the Phase I boost level it flashes up the light.
Tris
UK
Hi Rich,
Yeah, Richard suspected something like that when he looked at the chips. He checked with Regal and they said they were right. I wonder how many other people have trusted Regal and ended up with the wrong chips. It could be an easy way of making some extra money :mad: Although, I must accept it may just have been another unfortunate mistake.
Tris
UK
Hi Guys,
Just to keep you updated; Regal have said they want to contact EDS before replacing my chips with the right ones. It shouldn't be too long now! :)
Tris
Tris
UK
The car is now fitted with the correct chips and is running fine. It is a shame Regal didn't supply the correct chips to begin with but it is sorted now, even if it did take them nearly a month.
Thanks Arno and everyone else for your help with this matter.
Richie
aye aye.... what you gonna do now your cars working fine :p ;)
Tris
UK
Keep my fingers crossed ;)
Seriously though, next on the list for the engine is probably water injection, just for added piece of mind. I also need to sort the suspension out as it gets very bouncy at high speeds. I finish uni this year so hopefully I can get a proper job and have some more money to spend on it. I'm seriously considering buying a newer car and keeping the Cav for weekends and shows. Then I can have the time to get some serious power and not worry about the reliability. I don't want to stray too much from standard though as the car really is in exceptional condition and I want to look after it. I will probably stop at about 320bhp. Oh, and at some point I will need to upgrade the brakes. :D
Phase 2 problems
Phase 2 problems - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
Nike Air Max 97 Plus may be a hybrid design: Proven above may be the Nike Focus Kobe ONE Protro, the best pair from the upcoming Nike Kobe 70's line. However the shoe is called a 70's...
