Knock sensor FC 16
Diskutiere Knock sensor FC 16 im International Corner Forum im Bereich Technik; This morning my ecu light came on and stored code 16. (I have also been having boost problems for the last year. - not going above 0.5-0.8 bar -...
Andy K
(I have also been having boost problems for the last year. - not going above 0.5-0.8 bar - does feal like an ignition retard problem.)
What is the recomended advice ?
I have heard many things.
1) replace cable with screened cable back to the ecu.
I guess I should try this first as it's cheap.
2) re torque sensor. To what torque figures though ?
3) Fit a spacer. What was that about RDS ?
4) Could always change the sensor :rolleyes:
Any advice gratefully receieved.:)
Everytime my car goes to silverstone it gets worse. :( (not on the track though)
N
NotNormal
UK
Andy
Try checking and cleaning the terminals in the plug that joins the knock sensor/idle speed wiring loom to the main ECU loom (I think its a 5 pin one from memory) its usually located near the vent valve.
I've come across a couple of 16v's that have brought up this code and what has happened is the terminals have corroded a bit and so don't make great contact so causing a current drop too and from the sensor.
Worth a try before you start buying new bits and bobs.:)
Andy K
Ah Not. I'm blessed with your presence.
Ok I'll have a look at that connector.
rds
Andy i used the aluminium washer trick which at lot of vaux dealers have used successfully to stop this problem!
It seems to work on mine but ive got so much stuff on my car now i wouldnt know what affected what:p
Andy K
I checked the 5 pin plug and it;s like new.
I'll have to get the jack out and look at the red plug.
Do an oil change at the same time.
N
NotNormal
UK
Ohh well, thats the cheap option out the window - DOHH !!
Knock sensor FC 16
Knock sensor FC 16 - Ähnliche Themen
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
nike free run flyknit 5.0 womens: Sergio nike free flyknit chukka mens garcia will be sporting the new Coleman TW '17 shoe immediately at the Hero World Obstacle, which features a...
Why is my engine retarding ignition?: Hi guys, please help me with my Zafira OPC Z20LEH. Why is my engine retarding ignition? I have always felt i was missing top end power so i...
Ph4 on mitsubishi EVO8 turbocharger.: Hi, Sorry for english! I have written to Arno, but no reply as yet. When I first got my phase4 he sent me chips for a T34 turbocharger which I...
