Final phase 4 problems?
Diskutiere Final phase 4 problems? im International Corner Forum im Bereich Technik; Hi, I've had the full EDS phase 4 setup on the car for almost 2 years now. I am using the EDS/K26 turbo, 4 x 500cc MSD injectors, Bosch 909 Pump...
N
Neil Adams
Hi, I've had the full EDS phase 4 setup on the car for almost 2 years now. I am using the EDS/K26 turbo, 4 x 500cc MSD injectors, Bosch 909 Pump, Apexi AVC-R boost controller.
It's been some time since I last attempted to run the full phase 4 settings due to some other problems with the car, but now they've been resolved so I want the Phase 4 to work properly again.
On hard accelleration, the car seems to misfire / judder. This is happening between 1.5 - 1.7Bar Any idea's why? I'm pretty sure the spark plug gap has been narrowed already.
Also I'd like to set the boost controller properly. Phase 4 overboost should be 1.9Bar and then hold 1.6Bar. At what Rpm should the overboost be within. The K26 turbo seems to spin up at around 3500rpm ish so surely overboost should be from here to around 4500rpm?
  • Final phase 4 problems?
DD
I think your car is running much to lean, when you use the Apexi and not the correct mapsensor in the ECU. Also your boostvalues are wrong.
On a Phase-4 we run 1.5bar boost and overboost depends on how strong your actuator is. You also need 550cc injectors and the correct fuel pressure. Also please give your bosch909 to the bin and use the pierburg-pump!
Why don´t you run the complete EDS-kit altogether? Then you have no problems and also a lambdacontrol, which cuts the boost on full load, when the engine is running lean.
I also recommend, to use our new K26 with big turbinesection! We don´t use the old K26 for our Phase-4 any longer.
Regards, Stephan
N
Neil Adams
Thanks Stephen - Now I'm worried! I was the first purchaser of the full phase 4 kit in the uk and all I wanted was to do everything that EDS recommend. I was told to buy the K26 Turbo, the 500cc injectors and the Bosch 909 Fuel pump as well as a separate boost controller.
The goalposts seem to have moved :lol:
Will EDS swap all of the stuff I originally bought for the current phase 4 spec?
N
Neil Adams
Where did you buy it?
DD
So when the kit wasn´t delivered together with the EDS-boostcontroller, but with an Apexi, Wallace sold you a copy of the EDS-Software.
N
Neil Adams
The software can't be a copy because I found it quicker and easier to speak to Arno. Arno sent me the P4 chipset for the MSD 500cc injectors direct - as I previously had the 5th injector chipset.
(Picture of my ECU below)
I don't know anything about the EDS boost controller - I bought the Apexi separately from the USA.
DD
Ah ok, the EDS-Boostcontroller ist the small pcb on the top left edge of your picture!
When your car looses power at about 5800rpm, your valvesprings seem to be weak. Oberboost depends on the setting of your actuator and boost should be 1.5Bar!
Please check your fuelpressure on full load! It must be 4.5Bar when boost is 1.5Bar!
Du meinst 6bar oder?
TurboOmega
Wilhelmshaven
Nein, wieso, bei 1,5Bar Ladedruck 4,5 Bar Benzidruck, ist doch alles OK!!! Eingestellt sind ohne Ladedruck dann ja 6 Bar, alles OK, oder sehe ich das falsch???
TurboOmega
Samy
Samy
Borken
Falsch Stefan meinte schon was er geschrieben hat 4,5bar Benzindruck bei 1,5bar Ladedruck. Weil 3bar Grunddruck + 1,5bar = 4,5bar.
4,5bar sollte er doch mit abgezogenem Unterdruckschlauch haben, oder versteh ichs falsch?
N
Neil Adams
OK Thanks DD, I'll check the fuelpressure on full boost. I've set the Apexi to limit boost to 1.5 Bar after 4500rpm. It's only doing around 1.6Bar on overboost before that. The actuator is a Garratt 04 - should be ok shouldn't it?
DD
Yes, that seems to be ok.
@Corsa-A-LET: P4 mit dicke Düsen fährt 3Bar Grunddruck! :wink:
:oops: :oops: :oops:
wollte nur sicher gehen dasde ihm nicht wegen nem Schreibfehler falsche Informationen gibst. :wink:
Russ
Careful Stephan, isn't that tantamount to slander? :wink:
You and Arno have really had the wool pulled over your eyes about a few things, haven't you? :roll:
Wonder how many other things "lager" have blamed on Wallace to save face? :shock:
The rest of you - this is an english speaking section please!!!!
TurboOmega
Wilhelmshaven
@Russ
I'm sorry man, but not all of the members are speaking so well english as you and than sometimes we have to speak german for a short time ;-)
TurboOmega
Russ
@Russ
TurboOmega
Sorry, didn't mean to have a go! :oops:
Just meant that it is frustrating when we can't understand.
Wish I could speak German. :cry:
Sure, but not about this.
And Lager doesn´t copy our software :wink:
Maybe, maybe not.
They do have a history of that kind of thing though :lol: :lol: :roll:
Russ
I should also have said, the only reason people buy from lager
these days is to get EDS products!
I've done it myself :?
Although unfortunately here in the UK we have to pay inflated prices because lager take a very large cut.
Oh, and for anyone that doesn't know - EDS are not allowed to sell direct to the UK because lager have tied their hands.
What happened to the European common market???????? :x
Final phase 4 problems? - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
nike free run flyknit 5.0 womens: Sergio nike free flyknit chukka mens garcia will be sporting the new Coleman TW '17 shoe immediately at the Hero World Obstacle, which features a...
Why is my engine retarding ignition?: Hi guys, please help me with my Zafira OPC Z20LEH. Why is my engine retarding ignition? I have always felt i was missing top end power so i...
