Fault code P0170
Diskutiere Fault code P0170 im Z20LET | LEH | LEL | LER | NET Forum im Bereich Technik; Hi guys, I'm sorry for posting in english but the non-german speaking forum is closed. I've looked for informations on other forums but I didn't...
L
luke79
Hi guys,
I've looked for informations on other forums but I didn't found anything.
Can you give me some explanations in english about the fault code P0170 ?
I have this error in my ECU,and everytime I clear it, it comes back after a few days.
I run a phase II EDS with dump valve, modded airbox & vectra intake, downpipe and sports cat, ngk spark plugs.
thank you all
regards
L
luke79
the name is "air mass meter".
are there some other symptoms who could reinforce the supposition of a defective LMM, like bad engine idle for example ? because I have this problem too.
How much is a LMM from an Opel dealer ?
I suppose that it's a very expensive part. Is there a way to get it cheaper, my car is no more under warranty
Oktober
Oktober
Opel Astra G vorne links
250 € I think...
ebay?
It is possible. But it could be a problem in the fuel system.
Finally you should check the air mass meter. This error could be dangerous for the engine...
OPC Caravan
OPC Caravan
chance the airfilter :wink:
only original filter!!! because the oil on the filter
destroyed the air mass meter!
sorry for the bad english :D
mfg opc
L
luke79
mfg opc
you mean that the oil on my k&n filter has damaged the AMM ?
but if you're right, that should be the case of everyone, who's still running original filter ?!! :?
Fault code P0170
Fault code P0170 - Ähnliche Themen
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
Autoverkauf, ausländische Anfrage mit Zahlung via Paypal - Betrug?: Hallo, ich verkaufe gerade meinen Vectra A V6 (C20NE Umbau, Link) und bekam eine sehr komische Antwort, was mein "last price" wäre: Mir kommt...
[Sammelbestellung] Wavetrac Differentialsperre für M32: Hallo zusammen, wir machen im Astra-h-Forum eine Sammelbestellung für die Wavetrac Differentialsperre für das M32, wer Interesse daran hat, der...
ARP Schwungradschrauben mit ARP moly lubricant anziehen?: Hi zusammen! will demnächst mein feingewuchtetes Bastuck Schwungrad verbauen und habe mir für meine ARPs die spezielle moly lube besorgt. In der...
