f18 => f16, f20
Diskutiere f18 => f16, f20 im Antrieb Forum im Bereich Technik; Hello I have question about gearbox in astra' 97 with x18xe engine. Can I change my f18 on f16 or f20 gearbox ? Is it any diffrences in clutch or...
Brzoza
Hello
Is it any diffrences in clutch or axle ?
Thans for your help.
Regards
Ecotec
HSK Hochsauerlandkreis NRW
The Problem is the Oilpan, the F18 of your 97er X18XE is bolted together with the Oil Pan.
The F16 or F20 Gearbox does not have the Holder for the three Screws.
What is going on with your F18? Is the Differential broken?
MFG
ECOTEC
Brzoza
Sincerity i don't know
Now I have problem with 5 th gear - sometimes perf , sometimes no.
It's start when my rear engine arm was break.
Then my gearbox begin emission strange sound.
Mechanic tell me - it's differential
On my market price f18 is too high, and i think, put in f 16-f20- the price is very nice - low.
BTW form f18 and f16-f20 is the same, when i look at the gearbox.
Thanks for your answer, the problem is in oilpan - is it any chance to put inside my f18 - middle f 16, f20 ??
Regards
Ecotec
Sorry,
but the Axle Ratio is never the same. The F18 Gearbox has his own Axle Ratio, an the Differentil-parts aren t be the Same.
Your Info is not correct.
The F16/F20 have 3.55, the F18 have 3.57 etc etc.....
MFG
ECOTEC
rich
Niederbayern
but you can have F16 W3.94 and F18W 3.94
the better way and much more safe is always to change both !!!
rich
Niederbayern
it´s OK @ ecotech .. i beleve it to ...
but if you change all parts inside there´s no Problem
---> watch out for the different bearing !!!
f18 => f16, f20
f18 => f16, f20 - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
