c20let smoking ?
Diskutiere c20let smoking ? im International Corner Forum im Bereich Technik; Hi I have problem with smoking turbo. original K16 Oil comes from turbo to exhaust when accelerating and braking ( not every time ). When engine...
V
VSD
Estland
Hi
When engine is cold there is no smoke coming out.
I have changed this gasket ring which is on the turbine side and cleaned parts from old burned oil.
All ventilation pipes are clean.
Oil outlet pipe from turbo is clean.
Sparkplugs are clean, like new ones.
Oil is 10w40 Valvoline
Can anyone tell me what I have to look up ?
regards
Andres
V
VSD
Estland
Hi Micha
How old is my turbo - I dont know.
The turbo shaft has very little windage / slack - I think it`s normal
I bought this car some years ago.
It did not took oil.
Two times I saw similar smoke.
Car has been about one year only in garage (I did head works, new cooler,pipes, changing old parts - brakes etc. )
Last week all necessary things were done and I went to drive.
When accelerating and when I took leg off the pedal, from exhaust came smoke like from old bus.
Last weekend I replaced again this oil gasket ring which must stop oil going from turbo to exhaust .
Then I replaced this oil outlet pipe too.
Little bit better , but still smoke sometimes.
regards
andres
REDMAN
hinter der Eiche links
Hi Andres
Rear one if the car some time stood then avowedly that probably everything.
With the oil cork a well-known problem is and becomes ever worse with that the old turbocharger with the K16 turbochargers.
One should drive also none to light oil, otherwise the engine uses and the turbochargers too much oil. :?
I think times the oil (oil cork), old in your turbocharger, accumulated between turbine and turbine case, or however your turbocharger burns oil.
Drive again a time long and to showu times whether it improves, it should not be the case can it be that your loader soon broken goes. But that can have, simple times wait for and observe many unrsachen.
Sooy Andres for my bad English 8)
Greeting Micha
V
VSD
Estland
Hi Micha
My german is worse.
Please write it in german again.
I can use free-translator or I`ll find someone who can translate this.
regards
Andres
c20let smoking ?
c20let smoking ? - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
