WHERE CAN I GET OMEGA PISTONS FOR THE C20LET engine
Diskutiere WHERE CAN I GET OMEGA PISTONS FOR THE C20LET engine im International Corner Forum im Bereich Technik; as above WHERE CAN I GET OMEGA PISTONS FOR THE C20LET engine??? Cheers Boets
Boets
Belgium
as above
Cheers Boets
  • WHERE CAN I GET OMEGA PISTONS FOR THE C20LET engine
Boets
Belgium
86,50 would be perfect.
I'm running stock mahle 86,00 now
Samy
Samy
Borken
Then you can also go 86,25. And still have the option to put 86,50 in when the engine needs the next rebuild.
Boets
Belgium
@ Samy
I see you got aria's also now.
What would you recommend?
I'm aiming at 450-500 bhp. NON street use !!
Thanks!
Samy
Samy
Borken
For 450-500 hp both would be fine. Both use the same strong 2618 aluminium. The arias is better for more hp because of the lower CR. If you like to run long on the street you can limit the performance to 360-400hp and use a weeker softer aluminium like the z20leh or 4013 aftermarket pistons.
WHERE CAN I GET OMEGA PISTONS FOR THE C20LET engine - Ähnliche Themen
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
adidas neo lite racer mens: Beam Prohibit adidas neo uk Shades Purchase in the intro of the United states Atmosphere Pressure Lieutenant difficulty. within 1930, Bausch as...
Klasen Motors: Hello I would to share my experience : On October 2010 , i had my car remapped at KLASEN MOTORS with my first set up (I am not a...
