Thanks ASH , need help on fault code 13
Diskutiere Thanks ASH , need help on fault code 13 im International Corner Forum im Bereich Technik; Thanks ASH We received our goods , phase III chips for C20LET and phase II for Z20LET As you know ( or do not know ) the Astra / Kadett tS in...
W
WayneJ
Thanks ASH
As you know ( or do not know ) the Astra / Kadett tS in South Africa with the C20LET engine did not have a lambda sensor as part of the factory setup.
I soldered the Orange wire on to pin 24 instead of pin 28 as you instructed previously , but fault code 13 still come on after driving a short distance .
Fault code 13 : open or faulty lambda circuit
The powerwheel works fine
I can feel the the ignition is retarded
Can you offer a solution other than fitting a lambda sensor ?
No problem with the Astra Coupe with the phase II
W
WayneJ
EDS team
Any response would help
:evil:
Thanks ASH , need help on fault code 13 - Ähnliche Themen
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
Nike Air Max 97 Plus may be a hybrid design: Proven above may be the Nike Focus Kobe ONE Protro, the best pair from the upcoming Nike Kobe 70's line. However the shoe is called a 70's...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
