Oil Pump for the C20LET
Diskutiere Oil Pump for the C20LET im International Corner Forum im Bereich Technik; I know that SBD and others do uprated steel internals etc for the C20XE, but does anyone know if these can be used in the turbo pump or not? Or...
Allen Mead
I know that SBD and others do uprated steel internals etc for the C20XE, but does anyone know if these can be used in the turbo pump or not? Or, are there specific uprated ones for the turbo engine?
Am fairly certain that my pump is on it's way out.
  • Oil Pump for the C20LET
N
NotNormal
UK
Pumps are exactly the same between the C20 LET and XE. The only difference between 16v pumps is whether it is an early or late belt arrangement as the castings are different. All Arno recommends is to increase the pressure by putting washers in the release valve. Steel gears are only put in place to cope with the extra revs that throttle body cars run at.
But then I guess you know this by the answers on your same thread on migweb:rolleyes:
Allen Mead
Cheers Dave.
Only trying to get the best advice;)
Oil Pump for the C20LET - Ähnliche Themen
an initial look for the Nike Air Huarache this comes: That trend connected with tactile customization in trainers continues because Nike plans on releasing most of their iconic Sportswear workout...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
adidas neo lite racer mens: Beam Prohibit adidas neo uk Shades Purchase in the intro of the United states Atmosphere Pressure Lieutenant difficulty. within 1930, Bausch as...
C20LET oil pump: Hi! The rebuild of my engine continues...Now I need to buy new oil pump. Which one should I buy and why, or should I just buy the original Opel...
