The differenz between P3 and P3.5 is the turbo
pressure 1,15 and 1,25 bar. This means P3 has
about 315 and P3.5 about 330hp. The pressure
regulation with 3.5 is better, because it use additional
the data form lamba controll.
I hope this 'english' is good enough to understand.
Thanks GUNTER
OK so the different just a pressor sensor!!
My problems:
EDS send my a new switch and cpu bord, and i hope that work, because i have a OPEL meeting here in sweden in sunday with swedens biggest motorsport magazin, and they will make a reportage about my car
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku.
I'm A owner Corsa D A16LEL with few mods:
- wydech prosty...
Ladedruck Probleme Z20LET mit LEH Setup und EDS Phase 3,5: Moin Leute,
Ich hab ein Problem mit meinem LET, er hat ein ein komplettes LEH Setup und eine Phase 3.5 von EDS. Das Auto stand 5 Jahre ich hab...
