C20LET lambda sensor wiring
Diskutiere C20LET lambda sensor wiring im International Corner Forum im Bereich Technik; C20LET lambda sensor wiring -------------------------------------------------------------------------------- Hi How do I connect a lambda...
W
WayneJ
Hi
How do I connect a lambda sensor into the C20LET wiring ?
I`ve got a `94 Kadett 200tS , but in South Africa they were released without lambda sensors.
I`ve now fitted a lambda sensor and AFR gauge which work great , but need to connect this into the wiring for my phase 3.5 to work . I get a fault code 13 without it
Any info would be of great help
Crio
Crio
Nähe Kusel
You drive series without Lamda sensor, dont you ?
Can't you take simply a P3.5 without Lamdaregulation ?
C20LET lambda sensor wiring - Ähnliche Themen
Astra G coupe 2003 Z20LET, speedometer not working: Hello, And thanks in advice for everyone thats reading this and possibly trying to help. I have recently bought astra G coupe turbo, with Z20let...
Klasen Motors: Hello I would to share my experience : On October 2010 , i had my car remapped at KLASEN MOTORS with my first set up (I am not a...
X20XEV Phase3 is not producing the promised power: Hey, I hope you can help with a huge problem I have with my Vectra B X20XEV engine. I have bought a EDS Phase 3 kit for it and installed it with...
4x4 problem: ok i had a 93 turbo that got wracked and i put it al in a 91 4x4 caly xe... now the 4x4 is working for a few minutes or until i launch it a few...
