Boost levels K26 / arp bolts ?
Diskutiere Boost levels K26 / arp bolts ? im International Corner Forum im Bereich Technik; How many boost can i run with a K26 charger and original conrods, but with arp bolts ? Do i need to change the injectors / fuel pump / fuel...
GSI-TURBO
Do i need to change the injectors / fuel pump / fuel regulator ?
Pourous_Head_UK
I wouldnt recommend more than phase 3.5 power or you might snap a conrod :shock:
ASH
ASH
Hi !
This combination is many times used by us , its working !
The new conrod bolts are save !
regards ASH
tabs
ash are you saying the origional conrods will be fine if you just change to arp bolts
ASH
ASH
Hi !
Thats absolute korrekt !
I would spend for my engine the following :
2) new fuelpump
3) strengsthend con rod bolts , like ARP !
4) strong silicone for air intake
4) EDS phase 3.5 it
mfg ASH
Boost levels K26 / arp bolts ? - Ähnliche Themen
A16LEL Rough Cold Start: Cześć! Przepraszam za mój język, ale jestem z Polski i nie mówię dobrze po niemiecku. I'm A owner Corsa D A16LEL with few mods: - wydech prosty...
Crystal Pilsner glasses: If You Need A Gift For A NFL Fan Shop Here Officially licensed NFL merchandise available with team logos from Jerseys NFL.com - NFL merchandise...
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
