About Cali Turbo 4x4 lowering...Need info!
Diskutiere About Cali Turbo 4x4 lowering...Need info! im International Corner Forum im Bereich Technik; Good afternoon! Answer, please on a question about lowering Cali Turbo 4x4. Now on my car installed ammo Koni Spors, with stock Cali Turbo springs...
U
UraGun
USSR,Moscow
Good afternoon! Answer, please on a question about lowering Cali Turbo 4x4. Now on my car installed ammo Koni Spors, with stock Cali Turbo springs . I want to buy recommended to me Eibach springs with lowering 25 mm, whether will result it in problems with 4х4? Thanks!
AstraTurbo
Norwegen
You should buy a camber-kit from Dorfbrunnen Garage to adjust the camber on the rear axle. This will make your transfer box to last longer. With 25mm lowering (Eibach lowers 35mm!?) it shouldn't be a problem, but it's better to install a camber-kit to be sure than to change a transfer box later.
Please buy only Dorfbrunnen Garages camber-kit. I've seen other camber-kits but the quality is very poor compared to DGs camber-kit.
Good luck!
U
UraGun
USSR,Moscow
Thanks for the answer! At us in the country very few people is competent of this question, the Koni&Eibach dealer has answered, that in the catalogue at all fwd Calibra's lowering is more, and for Turbo only 25 mm. I shall look today a kit recommended you.
califan
Schweiz
I recently installed shorter springs (30mm) also with Koni sport. The grip is fantastic BUT the comfort is ... well ...there isn't any. The car tends to "take off" on uneven surfaces and "the landing" is violent, thus giving also a hard time to the chassis. I am investigating this and at the moment my intention is to revert back to the original springs.
If you intend to drive on a track, that's fine otherwise ...
Kind regards
N
Not_Too_Fast!
Kent, England
hi califan - what setting have you got the koni's set at? I am guessing you have the top adjustable shock absorbers?
I fitted koni shocks & standard springs, but when i set the shock absorbers to firm i was bouncing up and down, hitting head on ceiling :oops: :shock:
when set to soft all is good
califan
Schweiz
I tried both smooth and medium. It's like being on a roller-coaster
U
UraGun
USSR,Moscow
Greetings! At me now the softest setting ammo.
Next week I plan to adjust electronics. I have decided to try a hard way of tuning of Cali Turbo, so to say, the Japanese way. Has bought boost-controller Blitz SBC-id II, Blitz id-Meter, airflow controller A'pexi S-AFS II.it is necessary A'pexi ITC for setting ignition retard. will soon bring big front intercooler, results I shall write. ;)
AstraTurbo
Norwegen
The perfect setting of Koni adjustables are not at the hardest. You should try to set the Konis to absoulte firm and then turn 270 degrees to hard. Try that for a while. Actually, the main intension with adjustable Konis is to make them harder as the shock is more worn.
Why you buy all that japaneese electronics when you can buy Electromotive Tec3 ECU? :) Cost is 1700 euro and you can adjust your complete C20LET with a old laptop.
About Cali Turbo 4x4 lowering...Need info! - Ähnliche Themen
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
Any experiences K29/K26 turbo?: Hello! Now finally my rebuild of C20LET is nearly ready except turbocharger. Now I need some advise from you...I have been thinking 2 options...
Vectra A / Calibra Turbo power steering pipes 1993->: Hello! I want to buy 2 pipes which goes from power steering pump forward. Only pipes without rost and in very good condition. I am also interested...
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
rearwheel drive in a calibra?: hello..i have a calibra turbo 4x4...super car no doubt about it... :) the problem as you all know is the transferbox(verteilergetriebe) :evil: i...
