Wiseco Kolben / Eagle Pleuel für Z22SE
Diskutiere Wiseco Kolben / Eagle Pleuel für Z22SE im Biete Forum im Bereich Teilemarkt; War mal als Stage-2 für meinen alten 2.2 Turbo geplant, der ist aber in der Zwischenzeit verkauft worden. Somit sind die Teile nagelneu und nie...
P
pheeos
Paderborn
Somit sind die Teile nagelneu und nie verbaut gewesen.
Die Kolben setzen die Verdichtung auf 8.9 : 1 herunter, also optimal für Turboumbauen und sehr starke Kompressoren.
Also, Beschreibungen jeweils vom Hersteller:
4x Wiseco Forged Aluminium Pistons
Wiseco Aluminum Forged Pistons are designed to optimize squish or quench during compression/combustion cycle event, resulting in resistance to detonation and pre-ignition. The end product is longer engine life and increased horsepower potential. On and off the street, you can depend on the maximum strength and minimum variance of Wiseco’s aluminum-forged pistons for your sport compact vehicle.
Wiseco’s pistons outgun cast and Hypereutectic pistons, giving you stronger pistons and tighter tolerances than any other part in your engine, with less internal and external machining. Our advanced forging process and extensive heat-treat and finishing process assure you of the performance and reliability you demand from your engine.
Piston set include locks, wrist pins, and piston rings.
4x Eagle H-Beam Rods
Eagle GM 2.2 Ecotec Connecting Rods are heat treated, stress relieved, certified 4340 steel 2-piece forgings for increased strength. X-rayed, sonic tested, magna-fluxed, all surfaces 100% machined with extremely tight tolerances, bronze bushings for floating pins. The 3-D design offers reduced weight with no sacrifice in strength. Uses ARP 2000 bolts.
Passend für alle Opel mit Ecotec 2.2 Z22SE Motor
Kosten: 900€ VHB
edit: sorry, bilder sind ein wenig gross geworden...
Wiseco Kolben / Eagle Pleuel für Z22SE - Ähnliche Themen
like cocktail parties, wedding anniversaries, weddings or: Pandora Jewelry Charms Are usually correct way to measure your current wrist bracelet Pandora? Undoubtedly, the easiest way to get fitted to get a...
Klasen Motors: Hello I would to share my experience : On October 2010 , i had my car remapped at KLASEN MOTORS with my first set up (I am not a...
Z20LEH with EDS software: Hi! I am from Romania and i own a Opel Astra h GTC OPC. I have bought the car in 2007 from Gemany (it was new) and i have been to EDS for the...
X20XEV Phase3 is not producing the promised power: Hey, I hope you can help with a huge problem I have with my Vectra B X20XEV engine. I have bought a EDS Phase 3 kit for it and installed it with...
Wideband Lambdasonden: Wem etwas langweilig ist kann sich mal hier durcharbeiten. ich bin noch nicht ganz durch aber wollte es euch auch nicht vorenthalten. Quellen...
